Theo
(Theo, architectural maker)
March 5, 2020, 11:26am
1
Hi,
Quite often my Shapeoko disconnects from my laptop. Unsure why this happens, is the USB connection very sensitive?
Therefore I often need to resume afterwards. I don’t know what percentage or line of gcode because it’s disconnected and information isn’t shown in Motion.
Is there any way to avoid this or resume? Does Motion create log files, so I can find out what line the error happens on?
WillAdams
(William Adams (Carbide 3D))
March 5, 2020, 11:34am
2
To avoid this, address the EMI issue which is causing the disconnection — contact us at support@carbide3d.com and we’ll try to help.
To continue see: https://wiki.shapeoko.com/index.php/FAQ#Continuing_a_cut_which_is_interrupted
Have you set your USB ports to not be powered down by Windows? This is the default setting in Windows to save laptop battery power, and is another common cause of USB communications loss along side of EMI issues that Will addressed.
Theo
March 5, 2020, 1:19pm
4
Thank you. I’m looking at the wiki, but my g code doesn’t match up? What is my preamble?
(1001)
(T201 D=6.35 CR=0 - ZMIN=-34.9 - flat end mill)
G90
G17
G21
G28 G91 Z0
G90
(Adaptive3)
T201 M6
S21280 M3
G54
G0 X-237.024 Y-408.938
Z8
Z-3.23
G1 Z-3.865 F1270
G19 G3 Y-408.303 Z-4.5 J0.635 K0
G1 Y-408.189 F1900
X-236.92 Y-407.913
X-236.865 Y-407.563
X-236.89 Y-407.106
X-237.035 Y-406.561
X-237.342 Y-405.953
X-237.86 Y-405.307
X-238.564 Y-404.728
X-239.362 Y-404.286
X-240.214 Y-403.961
X-241.096 Y-403.729
G17 G3 X-244.718 Y-403.337 I-4.135 J-21.287
X-252.011 Y-403.248 I-5.829 J-178.577
G1 X-254.746 Y-403.242
X-271.159 Y-403.241
X-402.46
X-402.567 Y-403.201
X-402.652 Y-403.126
X-402.866 Y-402.723
WillAdams
March 5, 2020, 1:33pm
5
Here is your preamble (w/ comments)
Then the cutting begins:
Theo
March 5, 2020, 1:35pm
6
Thanks, So delete everything after which line?
Theo
March 5, 2020, 1:46pm
7
Sorry, additionally, how do I identify the “move down from safety height”
G1 X-149.205 Y-280.534
G2 X-151.231 Y-276.451 I65.355 J34.979
G3 X-157.624 Y-265.417 I-71.513 J-34.063
X-181.909 Y-243.774 I-57.68 J-40.276
X-198.068 Y-237.658 I-31.745 J-59.471
X-209.802 Y-236.133 I-13.258 J-56.12
X-218.859 Y-237.006 I-0.725 J-39.899
X-225.726 Y-239.42 I6.828 J-30.39
X-235.937 Y-248.293 I11.68 J-23.753
X-239.283 Y-255.745 I20.196 J-13.546
X-239.881 Y-260.255 I18.862 J-4.794
G1 X-239.841 Y-261.166
X-239.747 Y-261.841
G3 X-239.118 Y-262.389 I0.629 J0.087
G1 X-234.285
G3 X-233.701 Y-261.941 I-0.023 J0.635 F1270
G1 X-233.671 Y-261.846 Z-22.492
X-233.643 Y-261.754 Z-22.469
X-233.616 Y-261.666 Z-22.431
X-233.591 Y-261.585 Z-22.379
X-233.568 Y-261.512 Z-22.314
X-233.549 Y-261.45 Z-22.238
X-233.534 Y-261.401 Z-22.153
X-233.523 Y-261.364 Z-22.061
X-233.516 Y-261.342 Z-21.964
X-233.514 Y-261.335 Z-21.865
G0 Z3
X-275.921 Y-261.843
Z-21.23
G1 Z-21.865 F1270
X-275.914 Y-261.847 Z-21.964
X-275.894 Y-261.859 Z-22.061
X-275.861 Y-261.878 Z-22.153
X-275.817 Y-261.905 Z-22.238
X-275.761 Y-261.938 Z-22.314
X-275.696 Y-261.977 Z-22.379
X-275.623 Y-262.02 Z-22.431
X-275.544 Y-262.067 Z-22.469
X-275.46 Y-262.117 Z-22.492
X-275.375 Y-262.168 Z-22.5
G3 X-274.621 Y-262.389 I0.809 J1.361
G1 X-269.648 F1900
X-269.006 Y-262.357
X-268.222 Y-262.151
X-267.407 Y-261.742
X-266.69 Y-261.18
X-266.072 Y-260.508
X-265.552 Y-259.759
X-265.119 Y-258.957
G3 X-264.028 Y-255.486 I-13.152 J6.039
X-263.429 Y-250.053 I-36.58 J6.78
X-263.261 Y-241.849 I-161.808 J7.425
G1 X-263.249 Y-240.026
X-263.245 Y-238.202
X-263.242 Y-234.555
X-263.241 Y-224.525
Y-214.495
Theo
March 5, 2020, 2:25pm
9
It’s working! I think I’m getting the hang of it. Thanks Will.
system
(system)
Closed
April 4, 2020, 2:25pm
10
