I’m getting ready to have to resurface my waste board. Since my last resurface I have added the bit setter. Seems I have read something about unchecking the bit setter prior to doing a resurface. Am I correct or not?
Yes, that’s to have access to the full work area, or you could likely hit the bitsetter during the surfacing.
Disable it in CM, make a mark on the rail of where it was seated, temporarily remove it, surface the watseboard, then reinstall it and re-enable it in CM. (You may have to re-adjust its coordinates in CM, if you don’t reinstall it at the exact same position, but that takes a minute)
I wrote a doc on spoil board considerations. You can use it to help surface your current spoilboard.spoilboard_considerations.pdf (1.3 MB)
Uncheck the BitSetter box, but don’t forget to remove the BitSetter too, if you have to!
