Within Carbide Create 743 Pro.
My retract height is set 10mm and Z zero height is top of material.
I save G-code only only since I have that option.
Here is a snippet of the first lines of gcode. As you can see the Z is not being set for the first “G0” rapid, as a result the my bit is dragged across the surface.
This is not the behaviour I expected. Is this a known bug??
