Reverse Y axis direction Motion 640
When I attempt to initialize my machine, it moves to the lower right corner instead of the upper right corner. Then it throws a “HM08: The machine could not pull of the homing switch.” Error. How do I reverse the Y axis?
Shapeoko XXL with DeWalt
Carbide Motion PCB V2.4e
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 640
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: false,
“bitSetterEnabled”: false,
“bitSetterX”: 0.0,
“bitSetterY”: 0.0,
“bitZeroType”: 0,
“connection”: 1,
“lastConfigSent”: 0,
“lastProbeIndex”: 0,
“lastSizeOption”: 0,
“odometer”: [
“cleared”: false,
“minutes”: 0.0,
“startDate”: “2024-08-16”,
“travelX”: 0.0,
“travelY”: 0.0,
“travelZ”: 0.0
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -830.0,
“travelY”: -850.0,
“travelZ”: -100.0,
“version”: 0,
“webhooks”: ,
“workOffsetX”: 0.0,
“workOffsetY”: 0.0,
“workOffsetZ”: 0.0
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 6, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 40, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 5000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 400, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 100, Z Max travel, millimeters
Maintenance:
Travel (km) 0.00, 0.00, 0.00, 0.00 Hours since 2024-08-16
Queue Empty
Which machine do you have?
Which Z-axis?
Reconfigure per:
https://carbide3d.com/hub/docs/shapeoko-setup/
if the Y-axis is reversed with the correct configuration, power down and swap the two Y-axis motor connectors (on an SO3 — check w/ support for other machines)
It is listed as Shapeoko XL / XXL Kit - XXL with DeWalt S3KIT-XXL-DWT on the invoice. I got it back in March of 2016.
Z axis is belt drive.
The swamping of the Y connectors fixed it.
Thank you very much for the help.
