My first machine issue. Help. I forgot to turn on router swt after changing bit. Machine plunged into my board stock before i was able to hit “stop”. Now i reset everything up and router wont come on. I plugged router direct to outlet and it comes on. I gave bit setter and bit runner. I have reset machine software and reset everything a few times with no luck. Turned machine off etc. what could this be? Any troubleshooting suggestions? Help
Try unplugging the controller and the BitRunner and the power supply, wait a bit, then see if plugging things back in gets you up and running or no.
Depending on version you should also check (while unplugged) if the fuse needs to be replaced.
If still not working, and if in warranty, check in at support@carbide3d.com
Hi thanks. Unplugging all didnt work. Ill look at fuse. Where is the fuse? I didnt see it on the mother board in the controller. Is it inside bit runner?
