I’m posting this as kinda a hack for anyone running in a product setup where you need two CNC running. If you start with both units off and CM running, then turn one unit on and initialize, you can run a second instance of CM as administrator and then turn on an initialize the second unit. You can also change your personalizations to color administrator programs differently. A little clunky but works well.
I. Have an xxl and an xl. I only run one at a time. I learned to send the config each time because cm remembers the last machine ran.
