Designed sign, saved, now cannot find file
If you open Carbide Create and go to save, it should remember the last folder you saved to — does that help?
Trite answer: “It’s probably where you saved it”
You don’t mention what you created your design in… InDesign perhaps?
Either way, one way to find your file is to create and save another and note the directory the program shows when you save. Your other file is probably there.
If you are using windows, do a search for the name you created
having done this many times, using Windows File Explorer search function specifying file type, date modified, etc. Of course only on the PC.
Thank you. Would help if I did not have so many files~!
