I just downloaded CC into a new laptop after a catastrophic failure of my last one. I created a new project today and when I went to save the G code to a thumb drive I was asked if I wanted to save it as a Basic G Code or a GRBL.
I saved it as a Basic G Code and won’t be able to run the program until tomorrow.
I’m confused. You got this prompt while using the “Save G-code” button for the first time ?
“Basic G-code”, “GRBL”, and “Carbide3D Shapeoko3” (and a few others) are names of the available post-processors in CC, accessible under Edit/Select Post Processor. If you have the Shapeoko the correct post processor is “Carbide3D Shapeoko”, so I suggest you explictly select that (in Edit/Select Post Processor menu), and then Save G-code (again) for your project before running it.
Julian
I got the message while saving it to a thumb drive, something that I have never tried before. I just tried it again and did not get a similar message. I compared the file details between the thumb drive and another copy on the desktop and they appear the same.
Learning curve being exceeded
Thanks
Bill
I suspect it has nothing to do with the thumbdrive, but occurs on the very first use of “save G code” on a fresh install on a new computer when no post processor has ever been selected, and then you would not get it again afterwards.
I still suggest you double-check which post processor is now selected in the Edit menu, it needs to be Carbide3d shapeoko. The Gcode output is not the same if “Basic G code” or “GRBL” is selected and it won’t work well in Carbide Motion then
You want to select the type of machine you have. Generic gcode or grbl will work but might be missing some m or g commands a Shapeoko or Nomad would work better with.
