Just wanted to find out if others are finding that the screws become loose on the Sweepy 2.0 during cutting operations?
In fact one screw and washer fell off while the machine was running and I only found the screw (not the split washer)…looks like a trip to Home Depot is going to be part of my Sunday Errands
Since it’s a cam mechanism, it’s usually a matter of adjusting the bolts so that they nut is positioned so that things are held securely — I try to remember to check mine each time I remove/replace it and at the start of each working session as part of the checklist:
