Second pass on pocket toolpaths
I have a Shapeoko 4 and I am Running Build 729 and 556 of Create and Motion. For some reason when I run a pocket toolpath, after it completes the toolpath it goes back and does a second one time pass at the finish depth. My depth per pass and the max depth are the same so I can’t seem to figure out what’s going on. Wondering if it’s just a bug issue or if you guys have heard of this problem. Either way it really increases my cut time so I really need to get this fixed.
Thanks for any help you can give.
Post your file here. I will take a look at it
Please update to 741 which was just moved to Stable:
Its been updated to 742. I found a costly little bug in it this morning :neutral_face:
I have the latest builds of Create and Motion and I’m still getting double pocket passes?? I am attaching the file I am currently cutting. Thanks for any help!
Badge-BERTIE CHIEF DEPUTY.c2d (2.0 MB)
UPDATE: I still have no idea what the problem is but my solution is this; I set my depth per pass to .05 and my max depth to .03 and it only did one pass. IDK what is going on but there is a bug somewhere. But, for now at least I have a work around.
