Sending file from cc to cm
I’m seeing posts where people are talking about sending their files from cc directly to cm but I thought that with the latest versions that it was no longer possible. Am I missing something?
I just did it. CC 764 CM622 Works great. You must have the CM main screen up when you send from CC.
Awesome
Makes sense :slight_smile: That would be a good tidbit to know
Thanks
I use it all the time also. Mac versions of CM Beta 622 and CC764. The only thing I’ve noticed is that you have to select the Run screen before sending the file from CC. If your in the Jog screen in CM when you send the file from CC, CM won’t get the file.
not sure whats happening but it says that file has been sent to cm but i can’t find it anywhere in cm.i have motion in the run position.
Might be time to send a note to support. Might get lucky and get in the Que for a quick phone help.
Good Luck
So this feature is working well these days? I believe it has some issues in the past.
The current implementation has a .c2d file being sent — since the .c2d file has to be loaded and toolpaths extracted from it, partial file transfers shouldn’t occur.
I have had very few issues using this, If I have a problem, 90 percent of the time I have gotten ahead of myself. Very few times that CC has not sent to CM like I asked.
