Set Screw/Pulley
Hello, found a set screw on the work table after running a project, no big deal determined it was from the x-axis motor pulley.
Question (1) as the machine (ProXXL, Z-Plus) was provided, the pulley was on the shaft with the set screws toward the motor end. Since the x-axis pulley is slid onto the shaft farther then the y-axis motors the set screw for the x-axis motor is now “past” the flat portion of the shaft. Was the pulley supposed to be provided with the set screws on the far end of the shaft?
Question (2) since I am going around and adding lock tight are there only 6 set screws on the Pro model, ie 2 for each of the three x/y motors?
Thanks
Please contact us at support@carbide3d.com and we’ll do our best to assist.
