@Dustyboots: Your response must have come in while I was typing. I tend to ramble on a bit as you may have noticed.
I actually did the same thing as you did to identify the cutting area with the exception that I did it using a V-bit just barely dragging the bed of the machine. That gave me a little edge I can use for lineup that doesn’t get erased periodically.
I’m not currently planning on using T-Tracks but that may change as I figure things out. Thanks for the suggestion.
My actual surfaced wasteboard is at machine boundaries, right next to that on each side I have a t-track. If I need to clamp outside the working envelope I use that and prop up the ends of my clamps with a small piece of MDF. You could always add a t-track at the sides like me, or add a thinner piece of MDF with inserts outside the machine boundary?
@neilferreri Thanks Neil. I have some F360 experience through 3D printing but not any CAM experience. At the moment, I’m treating this as a learning exercise with the cost for doing it “wrong” just a piece of MDF. I appreciate your offer but would rather puzzle it out for myself rather than apply someone’s cookbook answer. I tend to learn better that way.
In case you’re curious. https://a360.co/2D9NM2t
Not for most anyway…I have a double thick wasteboard underneath.
I alternated holes in the grid, 8mm dowels and M5 clamp system.
I ran a test cut on some scrap plywood just to confirm that what I wanted to do was correct and discovered a few things.
I need to allow slightly more clearance on the through holes to allow the bolts to be more easily inserted.
I need to re-square the machine and do some calibrations before cutting the real board. As you can see from the photo, my holes are coming out oblong. I’m not sure whether that is out of square, loose belt in one axis or another or a need to adjust steps/mm in the software.
The bed of my machine is not quite level to my gantry as I got some onion skin on two out of the four holes I cut. I anticipated that which is why I plan on doing a leveling pass on the supplementary wasteboard when I get it mounted.
This one is aluminum, and I mount it on tope of an mdf one with threaded inserts (I don’t understand what problems people have with these, I’ve had exactly zero failures/pullouts), which is on top of (yes, I know…that’s a lot) my base t-track board. I do switch back and forth. The aluminum one is specifically for some sheet work where Z travel doesn’t make a difference. I usually cut wood on the mdf threaded one.
I think pretty much everyone with a threaded wasteboard finds there are some threaded holes that get used a lot, some that get used a little, and some that don’t get used ever. I kept track of that for my projects for a while, and came up with the radial pattern on the aluminum one - it has a lot less holes than one with a square pattern of holes every inch.
Looks good @mikep. I think that 3 deep is a bit of overkill but it’'s your machine. Just to be clear, Ihave nothing against threaded inserts but I happen to have about 300 T Nuts left over from another project so I’m planning to use those.
Yeah, the 3 deep is a bit much, I agree, came about because of a bit of laziness on my part too. I can mount the aluminum one directly to the t-track as well, I just don’t like taking the threaded MDF one off because it needs to be realigned when put back on.
Griff
(Well crap, my hypometric precursor device is blown…)
19
Ha ha, what’s that they say about like minds…? Nice to have the flexibility.
I have one board with just dowel holes for tape/CA work. Most all I do anymore.
You could use the router to place holes where it will reach, and then use the router to make a drilling jig to extend the holes further left and right.
The drilling jig could be as simple as a board with two holes to place dowels through to align with the holes in the waste board, plus another couple of holes to place a drill bushing to use with a hand drill.
I think your circles are ovals because you’re plunging too quickly with a bit not moving x/y. If you can add a ramping motion or a lead-in, it might help.
Possible. I set both the counter bore and through hole up as pockets in carbide create using the programs default feeds and speeds. I’m using a 1/8" flat end mill. Both are showing the same type of deviation showing oval to the right rear. Probably be the weekend before I can get out to the shop to start chasing it down.
@Dreamtym I believe you mentioned you have 3D printer experience. If you’ve done a lot of 3D printing, you’ve probably seen that shape for circles before. Probably something out of square or something loose causing motion that is out of square.
Thanks, Neil. You are right. I suspect a loose X belt but as I said previously, I probably won’t get out to the shop to do some more calibration and testing until the weekend. Unfortunately, I’m at that stage of a cold where doing nothing is driving me crazy and doing anything requires more energy than I have.
I currently have a second larger CNC to make wasteboards for my XL, but before I did, since the wasteboard is wider than deep, I rotate it 90 degrees, machine the holes in the front half, shift the wasteboard 180 degrees, then machine the rear half with the same gcode file. Make the hole pattern symmetrically spaced from a center line. Place Job Zero in that line. Basically, I divided the board in half and rotated it to fit the machines working area.
I have made many project cuts that seemed too big for the XL by shifting the longer stock along the Y axis. There is no limit to how long it can be as long as it is not over 32 inches wide. I often use dowel pins to line up the stock between cuts.
Excellent point, @Freddie2, to put the origin of your pattern along the centerline to facilitate setting up the board. I appreciate the suggestion. Too many years of measuring from a corner I guess. I hadn’t even considered setting things up differently.
For the Autodesk challenged here is a simple wasteboard in Vcarve based on the original Winston Moy XXL wasteboard.
A couple of cons of this design:
3/4 MDF is more solid but it blocks access to the sides so I have take the wasteboard off to do tiling in X unless the material is very thin.
His design is taller than the machine limits if bolted to the inside of the rails which means you have to hang it over the front to machine it and surfacing requires the top 1-1/2 inches to be hand sanded.
