Hello, I just got a 4 XL machine. I do not see where to setup the xy location for the bitsetter. I jog the machine over to the location above the bitsetter, enable it but cannot select current location as the reference for bitsetter? Not sure if this was changed recently, but every screenshot I’ve seen shows that you can select “Use Current Location” after positioning above the bitsetter. After setting a generic zero and seeing if it will check the tool, it moves to the northeast corner and begins plunging the bit towards the wasteboard, so it is clear that the location of the bitsetter is still not set.
Thanks for any help.
