This is a reasonable approach. If you want you could record the previous job origin into a Quick Action that would take you to that position.
To get the machine co-ordinates in CM, you don’t have to Clear Offsets. You can click on the text ‘Position’, and it will switch to showing the Machine Co-ordinates.
Finally, if you have to re-initialize for any reason, then you are subject to the precision of your homing switches - they may not trigger at exactly the same place, and so you can be off by that amount.
