Hi All,
Thinking about adding Carbide’s VFD to my Shapeoko 3. Carbide motion 640, HDZ, board 2.4e.
Any concerns and others with VFD, are you happy ?
Thanks !
Brian
Hi All,
Thanks !
Brian
If you take the leap, make sure everything is powered off before connecting the VFD to the control board…
I run the C3D VFD on a standard size SO3 with an HDZ. Its a great setup. If you’re currently using the Sweepy 2.0 with the router you’ll want the Deep Sweep to go along with the extended nose on that spindle.
