I got a shapeoko 3xxl used and for some reason every time i try to cut something simple, it carves through the piece into the spillboard. I have a bitzero v1 and i use it every time but it just doesnt want to set the z axis. I tried manually zeroing it to the top of the piece which worked once and then it started doing it again. I use a capiler to measure each piece so i know the thickness is set right. Im just looking for any help on why this is happening.
May need to check which Z axis is selected in the setup menu. There are two versions, one is an upgrade and has different offsets with respect to the spoil board and will cause this issue you are experiencing.
May need to check if you are setting your Zero point on the top or bottom (user selectable) of material as well.
A common reason can be the Z you choose during setup in CM. The HDZ has more steps per MM than an Z-plus. If you told CM you have an HDZ but have a Z-Plus then you get more steps and you cut deeper than expected.
The HDZ has a bearing at the bottom of the lead screw. The Z-Plus has a black block but there is just a hole with no bearing on a Z-Plus. If you have a belt Z (older SO3) not sure about steps per MM but that could also be a problem if you choose the wrong Z in setup.
You mentioned that you were measuring your stock. That is critical. If you have the correct Z in setup maybe try using bottom of material during your CC setup. I have been using bottom of material about 90% of the time on my projects if I am cutting all the way through. If I am not going to cut all the way through on a project I use top of material. I replaced my spoilboard on my SO3 XXL in July 2025 and have very few scars on my spoilboard. The only scars I got was on the first version of CC that had the cutout tool path added and it would consistently cut through the material and cut into the spoilboard. That may have been fixed but I quit using the cutout tool path.
There is one caveat about using bottom of material if you use the rapid positions. There is a Z+6MM that can be problematic if you use it. You need to jog off the material to perform that or the bit will crash into your stock if using bottom of material.
Using bottom of material will be a change to your work flow but for me it is second nature now and has worked well for me.
So after i set my z zero i need to jog the bit 6mm avove zero?
Jogging to 6mm above the current Z-zero is a useful check, and I do it just about every time (and check w/ a 6mm thick piece of acrylic), but it doesn’t need to be done.
Please post a photo of your machine and a detail photo of the Z-axis.
Let us know which Z-axis you have configured for (the value for $102 in Debug will show this).
Show us how you are setting zero — note that both the v1 and v2 BitZero set Z-axis zero in the same way, so it could be that you are too deep because you selected v1.
For the documentation on this see:
and
Here is my machine. Not sure what z i have. I also dobt see an option to change it in the settings but i am running version 622 that came with the machines computer. If i upgrade will the bitzero v1 still work?
That seems to be a 3rd party Z-axis (it’s not a belt-drive, Z_plus, or official Carbide 3D HDZ).
The current version of Carbide Motion supports both v1 and v2 BitZeros.
You will need to determine what the correct number of Steps/mm for $102 should be — check the Debug area and see what this is currently set to and make note of it if the computer was previously configured.
Setting the zero at the surface of the MDF, jogging much an inch or two, then measuring the actual travel should allow you to get close.
Moving this to Unsupported since the specific upgrade being discussed isn’t a Carbide 3D product.
Turns out it is a z axis from cnc4newbie and the link is below. I dont understand why the person i got it from had no issues. Im assuming he set up the new z axis correctly. Can anybody recomme d the order in which you do all of the setup and everything.
