Shapeoko Post Processor for VCarve Pro Error
I’m trying to install the Shapeoko Post Processor for VCarve Pro and when I install the “mm” version I get the following two errors.
See attached.
Has anyone come across this before?
I have attached the post processor file I am trying to use. (added .pdf so it could be uploaded, please remove .pdf to open)Shapeoko_mm_TC.pp.pdf (147.6 KB) )
The problem is you downloaded the web page, not the underlying text file:
Line 7 is:
<!DOCTYPE html>
Thanks Will, that was the issue. For some reason the “inch” version downloaded correctly but the “mm” did not.
Appreciate the quick response.
