Just got my Pro built and ready to go. The first homing attempts keep going to the front right not the back right. Any ideas what could be causing this issue? I double checked all of the connections were correct.
Even though you said the connections are correct, it sounds like the stepper motors are wired incorrectly. If you haven’t already, I’d contact customer service to get sorted out.
You can try swapping Y-1 and Y-2 on the control board.
There is also a GRBL command you can send to reverse it but someone else would have to help you with that.
That was it! I swapped Y-1 and Y-2 and it worked. Thanks for the help!!
