Shapeoko Pro XXL X Limit Switch
I just recently received my Shapeoko Pro XXL. Got it assembled and went to initialize. Problem is it goes straight to the right side and doesn’t stop. The x limit switch turns red but doesn’t stop the motor. I’ve tested the switch by swapping with the z switch. I’ve tried using the wrench to verify the red light on the limit switch comes on, the light on the board comes on, and the computer sees the limit switch activated in carbide motion. I have tried reversing the wires by flipping the harness with no luck. I don’t know what else to try. I have the setting right like the manual says also.
Nothing comes to mind if the switch does activate and shows up as such in Carbide Motion…you should contact support@carbide3d.com about this
