Shapeoko Program Info
Wondering if anyone has come across this problem…When cutting gcode the machine countdown stop at 80% more or less…but the machine continues to cut and then freezes at the end once it is finished cutting and I have to literally shut down the program to get the router to rise
Could you provide a little more information? Are you using Carbide Create and if so, what version?
Note if your word is too close to the end boundary of the machine, it will stop rather than try to go beyond where it was intended.
