I have been using the shapeoko 3 for 2 years without any major problem, thank you carbide. Lately it has been having some strange problems, twice in a row during a cut (pocket cut) the Z started to dig indefinitely slowly for a little over 10 cm properly. But for this post I would like to focus on a problem that makes it stop cutting randomly. So during its process it suddenly stops and I lose control, so I have to disconnect from the serial and reconnect it to resume cutting from the beginning.
I could notice:
-Stepper drivers are not hot
-I changed the USB cable
-No vacuum cleaner can cause EMI
-Connected to a MAC with UGS or Carbide motion same problem.
-Never stops at the same place
-When it gets stuck the three leds on the stepper drive are lit up
-Always in a pocket cut (no strange g-code command)
I don’t know what to do, I’m thinking of changing the stepper driver.
Do you have an idea? Thank you.
I would be more concerned about wood dust affecting the carbon brushes causing premature wear, and affecting lungs and overall health — please use dust collection, and if that’s not sufficient, a filter mask or respirator.
There is a 10-step plan which support will e-mail — it and more used to be on the Shapeoko wiki which is now off-line. You can see it in the Wayback Machine:
Usually if the obvious things don’t address the disconnects it’s something beyond the machine — heavy load on the same line such as a compressor, once it was a failing transformer and went away when the power company replaced it.
Please be patient w/ support and we’ll do our best to work through this w/ you.
