Shapeoko tech support
X axis stepper motor not working. How do I get a replacement.
Contact mailto:support@carbide3d.com. They will troubleshoot with you, to determine if the problem is the motor, wiring or controller.
The motor is actually least likely to be the problem.
We have a list of SO3 spare parts at:
https://my.carbide3d.com/
https://my.carbide3d.com/gettingstarted/shapeoko3/
and the motors are at:
However, the motors almost never go bad β€” it’s usually a wiring fault in the wiring connector/extension:
and note that quite often such a fault will damage the stepper driver on the controller, requiring that it be replaced:
