Should a cut path follow every little detail of the artwork?
Someone on another forum asked me for something I hadn’t given much thought to. Could the cut line my vector app draws be simpler, with a minimum rounded corner?
Up to then I’d been treating that line as something that should stay faithful to the shape. It follows the outline of the artwork, and the closer it follows, the better. That was the whole idea.
The request made me look at it the other way round. That line isn’t only there to look right on screen. Something has to physically travel along it, and a tiny notch that looks accurate in a preview might just be a nuisance when it’s being cut.
So now I’m stuck on where the balance sits. Simplify too much and it stops matching the shape. Simplify too little and you get a path full of details nobody wanted.
For those of you cutting shapes from artwork, how do you deal with tight corners and tiny details in the outline? Do you clean up the vector first, or sort it out in your CAM software?
It’s subjective. If it’s a rustic looking job, the imperfections in the geometry may be intentional and preferred.
V-carve can get all the detail at the surface level if that’s what you desire.
Rest milling can improve detail, but only to the radius of your smallest cutter.
If you want the vectors smoother, edit them. If you’re piecing things together that have to match or fit precisely, make sure you account for tool radius.
This is a function of the design and the toolpath used trying to realize the design in cut material.
A V-carving can cut with great verisimilitude, but yes, inside/outside contours or pockets are limited by the radius of the smallest tool used.
Could you upload a file/design which you are having difficulty with?
Thanks both. No particular file, I was asking in general. When a vector comes from an auto-trace rather than being drawn by hand, what do you usually end up fixing before you can cut it? I’d like to know what would actually save you time.
I’ve learned to spend more time preparing the image and adjusting the tracing parameters rather than cleaning up afterwards. Larger, high resolution images to start with. Redrawing or erasing jagged edges with anti-aliasing. A lot of times, just adjusting the contrast helps.
If there are still imperfections on the trace I don’t like, I’ll clean them up by moving or deleting nodes. In some cases, selecting the offending nodes, toggling them to sharp then back to smooth can help. (I’ve been lobbying Rob to sweeten up the smoothing algorithm. :wink: )
That’s really useful, thanks. Fixing the image before the trace instead of the trace afterwards makes a lot of sense.
Of the steps you listed, which one takes you the most time: getting a clean enough image to start with, or the node cleanup at the end? If a tool could take one of those off your plate, which would you pick?
It really depends on the image. I usually start first with a trace in CC, adjusting the thresholds to get the best I can. If it’s still too rough, then I go to editing the image.
I’ve heard many claim the trace in Inkscape is better, although there are more controls to learn.
On a church picture ( a lot of straight lines) I used Paint.net and the Inking option.
This allowed me to control how the edges were determined.
Then I traced the 'inked" version using Inkscape Trace with the Centerline option.
Exported the SVG file
Imported SVG into CC.
Seems to look good, I but have not cut in yet.
The result slowed down CC because it was almost all open vectors.
Any move/translate/scale operations were effected. It finishes, just have to wait.
I sent it to Rob and he understands the issue and is working on these kind of torture files for future releases.
Original cropped image.
Inking image
Thanks Tod1d, that makes sense. Starting with the CC trace and only going back to the image when it’s still rough sounds like a sensible order. When you’re adjusting the thresholds, what’s the part you most wish worked better?
Thanks for sharing this, jtclose, and for the images. Open vectors slowing CC down is really useful to know. For a file like that one, what would you most want to come out differently from the trace?
I had to open up my dictionary for that one:
Verisimilitude is the quality of seeming true, real, or believable.
The word comes from the Latin roots vērī similis (“having the appearance of truth”) and -tūdō (an abstract noun suffix). While it implies a likeness to truth, it is distinct from strict factual reality; a story, artwork, or theory does not have to be objectively real to achieve verisimilitude—it just needs to convince the audience or hold together logically.
I will stay with the current results and have some patience to let it finish.
C3D knows about the performance issues and will be resolving it.
Dang. Another great education. Thanks !
Thanks jtclose, good to hear C3D already knows about it and is working on it. I appreciate you taking the time to share that example.
Here is the front side etch
The steeple and clock faces came out really crisp, and the tree still reads clearly with that many fine lines.
When you really look closely, you see the issues.
At 4 feet and further it looks good.
The concept of verisimilitude is true.
Exact is not always the best.
hey guys,
What do you think of the quality of my product’s vectorization function? honestly i think its very good…its 100% vector. not a image pixel in there
I did some very unscientific testing while carving this church picture.
The image stats
2160 x 2760 pixels
I used @xenith image to mesh generator.
The mesh stats.
Facet Count 5956680
Vertex Count 2983259
Note: The vertex count and pixel count are near 1 to 1, not sure why it is not exactly the same.
In Fusion, I used the same mesh data for each test, but scaled it up by a factor of 2 and windowed into smaller areas. I imported the mesh in Millimeters, but I work in inches.
I used a roughing bit, then a series of decreasing radii ball end mills ( 3/4, 1/2. 1/4, 1/8, 1/16 and 040 diameters ). I used a Scallop operation for all paths. I do adjust the REST resolution for remaining material.
Church2 - Scale factor of 2 Inches per vertex 0.003645
Church2 - Scale factor of 4 Inches per vertex 0.00729
Church2 - Scale factor of 8 Inches per vertex 0.01458
Yep, I screwed up the origin.
I was looking for a sweet spot where the carve looked as good as the mesh.
Church4 example was probably scaled up a bit too much.
As with any image to mesh process, the resulting mesh has warts as you get closer.
The material is pine, so it goes to mush when you try to carve too much.
Not sure if this helps.
Thanks Jim, this is exactly the kind of test I was hoping someone would run. Seeing the same mesh at 2x, 4x and 8x makes it pretty clear: past a certain point the bit and the wood stop holding the detail, and the mesh warts start showing instead.
So my takeaway is that the cut path doesn’t need to chase every little detail. It needs to match what the tool and the material can actually hold at the size you’re carving, and what reads at viewing distance (your 4 ft point)!!
