One thing I went back and forth on while building my vectorizer was whether to ask for the final size before converting anything.
Most tools trace the image as it is and leave sizing for later. I ended up asking for the print width and resolution first, so the shape is matched at the size it will actually be made, not at whatever size the PNG happened to be.
For printing that works well. For cutting I’m less sure it’s the right starting point, since tool radius and material matter as much as the drawing.
When you bring a traced image into Carbide Create, what do you set first? And what would you want a converter to ask you before it starts?
Vectors are scalable, so it doesn’t much matter (in my opinion). I like to trace my line drawings, and I really like center traces. But if I am building 3d, I still hand trace for building components.
Thanks cheu, that’s fair, and it matches what I’ve been hearing. Centerline traces keep coming up for line drawings. When you use one, what would you most like to be better about the result?
If it were possible, I would like closed vectors on centerline traces. As is, I find it is just as much work to fix the traces as it is to draw new vectors.
Thanks cheu, that’s a clear one. If fixing a centerline trace takes as long as drawing new vectors, the trace isn’t really saving you anything. When you say closed, do you mean the ends of each line joining up into a shape, or each line coming out as a thin outline you can cut?
