Side Skirts do not fit
After I installed all of the MDF Strips, the two side skirts for the Y axis do not fit,
Post photos?
Have you tightened the hardware yet? Maybe loosen everything and see if that then allows shifting things to get things lined up?
I tried to move the MDF strips, but when I tighten the screws, they move back. There isn’t enough room for the plates to fit between the MDF strip and the Y-axis arm.
Again, can you post a photo? It would make it much easier to diagnose.
What if you remove the MDF strips and then loosen the hardware holding the Hybrid T-tracks in place?
I was able to mount the side skirts by removing the MDF strips
