Sign design help
Rhodes.c2d (608 KB)
new user with Pro XXL and having trouble with sign - trying to leave letters height of material and cut out around them. Any help is appreciated. I am running CC version 757.
Opened your file and got:
38 vectors used for the large lettering, so we simplify that a bit:
This would seem to be the original geometry:
to resolve the overlap, go into Trim Vectors:
and click on what is not wanted:
until one arrives at:
OK
OK
then use Join Vectors to close:
The text seems to have changed size:
so we restore that and delete the extra geometry to arrive at:
The most straight-forward way to make the requested cut:
Is to draw the surrounding geometry:
(it may be any shape)
Select it and the elements which you wish to stand as islands in the toolpath:
and then assign an Advanced V carving toolpath with the Pocket Clearing Option:
Trying to use a contour will raise the problem of whether or no a tool can cut a given interior feature.
Attached as a v7 file:
Rhodes_v7.c2d (1.1 MB)
