Hi All - Hoping someone can help. I’ve designed a relatively simple sign, importing and tracing a photo. The VCarve toolpath I have created estimates 713 minutes to mill!!! This can’t be right.
Attaching the file here. Could anyone take a look and let me know what i did wrong, or what I could do to change this to a ‘normal’ working time?
You’ve got a lot of very small vectors, there’s going to be a lot of time just in moves, plunges and retracts. Also, with very small details, you may find that a sharper angled V Bit will work better.
If you want to try removing the very smallest details, under ‘Select’ there is ‘Select Small Regions’. You need to ungroup everything, then select all of the stuff you want it too look at. The values there are actually the maximums that get selected, I think they are called minimums in the sense of “that’s what’s left if you delete this stuff”.
4 mm may be deeper than you need, how’s the look at, say 2mm? Also, the 1/4" clearing bit may be too big, there’s a lot in the design (letters particularly) where it doesn’t fit, so all the clearing is happening with the V bit. Try 1/8" instead and compare. You may also find that not cutting as deep allows the larger bit to fit.
Finally, what version of CC are you using? On V8 beta, I see a time of 491 minutes, which is still long but better than what you are seeing.
Original - 491
plus Only 2mm deep - 413 minutes
plus remove 1mm/ 0.5 mm² elements - 277 minutes
Hey, thanks for the suggestions. I got it down to 426 minutes. I’m using CC Pro, but not sure of the version (assuming it’s the latest?)… How do I confirm, and get it down to the 277 minutes?
Thank you, very helpful. Now… when I try to toolpath a plug inlay of the same VCarve the new version of CC Pro shuts down every time it starts to calculate the toolpath. Assuming this is a bug in the beta? If so, is there a workaround? If not, how would I revert to the previous version?
Lol, I’m laughing because I’ve tried the same thing. But then I spend a few hours each day for a week+ editing the picture in CC. Half+ of the little specs should be deleted. Other areas can be combined to make 1 area instead of 5 or 10. Keep in mind that the vcarve will only go deep enough to touch both sides of the cutout. If you limit the depth (shallow) too much it will need to make multiple passes which adds time and might leave fuzzies… IMO this would be good for a laser, but long for a cut. I would also separate shirt from face then invert shirt
