I am trying to make a jig to hold a wine stopper to vcarve an image. I just upgraded to v743 and the simulation seems wrong. I created a pocket that is .75" deep with the #251 down cut bit. The simulation looks like it is doing an inside contour cut. Will someone please take a look at this file to see if it is me or the new version of CC 743.
I think the simulation was just an illusion. When I moved the view around it showed correctly. Since it was a new version I thought something was wrong. Thanks for all the help and support.
I posted the pics in What did you cut on your Shapeoko/Nomad today. To close out this thread here are the pics. I used a 20 degree vee bit to cut the pattern on a flat surface. I prefinished the piece on the lathe with sanding and Yorkshire grits. After painting I resanded from 150-600 grit and put the Shellawax on top.
I cut the blank to exactly 2" and cut a hole in the mdf for 2" on the Shapeoko with 4 holes to bolt it down to the spoilboard and it fit perfect. If the blank had not fit I would have taken the jig to the table saw and cut an 1/8" slit from one edge to the center hole and put a clamp on to hold it in place while machining.
