16dash16
(Dylan Lotter)
1
Has anyone seen an issue when exporting an SVG from Adobe Illustrator, that it is resized when importing into Carbide Create?
I created the attached design, which should have a diameter of 180mm. When I import the SVG into Carbide create it seems to resize it down to 135mm
WillAdams
(William Adams (Carbide 3D))
2
Export as an SVG (may need to use “Save for Web”) and be sure to clear the “Responsive” checkbox.
system
(system)
Closed
4
