is there a way to change “radius” to diameter when making a circle?
or do i have divide every time to get the diameter.
thank you
After making the circle, select it:
then use the Scale tool to change the size based on diameter:
Apply:
Done
Got it, Thank you so much
i work in MM a lot and never whole numbers
thanx again
