Sizing object onto work piece
When I download a clip art from the library the image is huge and is bigger than the work piece I have set. Example a 5x5 inch piece of wood or 127 mm x 127mm . I can’t get the image to fit on the grid, what am I doing wrong ?
I think that once you import it, you need to select it and use the ‘Scale’ operation. You can then use the selection points around the bounding box to resize it (useful if you want to size X and Y independently), or enter either the height or the width in the properties panel on the left to have is scale both X and Y (preserve aspect ratio).
I find it helpful to group the vectors so the image will be treated as one element. Then resize as suggested by mhotchin.
Bill
Thank you I will try that
Thank you I will try that as well
