I don’t know how things line up for other machines but on my Shapeoko 5.1 when the program stops and asks me to change the bit, it stops right above the t-track. When I change bits, specifically in my 1/8" collet, the bit often drops out on its own which means it’s dropping, point first, about 4" onto the aluminum. I know it’s not that big of a fall or anything, but for an especially thin bit this might chip off the point.
As I’m thinking about this, i do wonder if this is a setting in the controller and not one set by CM or CC, but if it is something that can be changed, it would be great if the bit could just drop onto the MDF
When I loosen my bit on my Dewalt router it has a button to lock the spindle. I use left hand and my thumb to press the button and use my little finger against the bit to keep it from sliding out. I think the Makita/C3D router takes two wrenches to tighten but there is the button to hold the spindle so try the thumb and little finger. My Dewalt is positioned so the button is on the left side making the finger trick work. So put a pad under the bit to catch it should it slide out. A piece of foam or styofoam would work but make a small box with the padding in the bottom to keep the bit from rolling off the pad.
I loosen up the collet nut enough to continue with my fingers and pull the bit out when it releases enough. I also put a small piece of thin cardboard below the spindle where it stops for the tool change. I have no idea if it’s possible to change the X/Y coordinates for the tool change. My process is baked into my workflow at this point. Sorry if this does not help you.
I’ve had it happen too. Some bits release from the ER-16 collet more easily. Cork is also a good safety net for underneath. I have a big roll on hand for making cushioned sanding blocks and non marring clamp surfaces.
BTW on the 5/5.1 Pro 2 x 4 the Tool Change spot is precisely X -100mm and Y+30mm from the front right travel limit.
