Snap to grid shortcut in v7?
Is there a snap to grid toggle in V7 via shortcut or single button? The “snap to grid” button I’ve seen in old videos is gone. The only way I can see is the View menu.
The only control for this is the menu.
For a list of available shortcuts see:
https://carbide3d.com/carbidecreate/shortcuts
Further question on keyboard shortcuts. Is there a trick to "nudge selected item one grid step? Because that doesn’t work for me on CC 778.
Select a vector and hit N, and then select a node.
Hit keyboard arrow keys.
Watch nothing happen.
I’d add a screenshot, but its like that “like this, but not hot” water picture.
Nudge w/ an arrow only works for a selected object/selection — it does not work in Node Edit mode for nodes.
so the process for making a rectangle larger by 2mm and shifting to the right by that amount would be:
  1. Make a vector.
  2. Align that vector to the “stable” side of the rectangle
  3. Resize the rectangle 2mm
  4. Align the stable side of the rectangle to the vector
  5. delete the vector.
Is there a better way?
oh wait. you just told me.
resize the rectangle by 2mm, then select it and hit the arrow key once, assuming the grid is set to 1mm.
