Well, I did it. I was cutting some Baltic birch today, it started misbehaving on corners, So I hit the pause button. Found the pulley off My Y2 stepper Sitting on the table, with some of the stepper shaft still attached.
I tightened my belts a few weeks ago, and it’s been running without issue until today. But I’m assuming this a result of belt too tight? Any suggestions?
Guitar string tight can be interpreted a few ways, like if you’re playing one of the big strings all like “juggah jah juggah jah” or up on the tiny strings like “mee-daleeee meeedaleeee weeeeeee”
Based on the sound effects I wonder if the correct tension could be quantified with an electronic guitar tuner. I will try it and see ifni can get a reading. Great description of the situation.
Bob, I think others have tried guitar tuner for the belt driven Z-axis, I can’t see it working as well on the X/Y rails, since the belt is in contact with the extrusion. I notice different sounds from Y1/Y2, I’m sure its due to the drag chain and controller mounted on Y1 rail.
Anyways, I got a new motor and backed off the belts a tad… Thanks for the replies guys.
