Are the mounting holes/locations for the homing/limit switches the same for the XXL/XL as the standard SO3?
Any mounting hole changes with the new design?
The mounting holes are the same, save for the fact they are only located on the intended side of the plate now (the positive side of the X axis, the positive side of the Y axis). Location was raised about 2mm to provide more clearance for the standoffs, but otherwise the positions are unchanged.
The only other change is of course the addition of PEM nuts into the plates, instead of using the traditional screw + nut system.
-Edward
