SOLVED: CC 876 - check box "Flip Inside/Outside"
I saw your youtube video concerning the “cutout Toolpth” downloaded and try the software
old:
new:
The new check box “Flip Inside/Outside” is not a good idea:
  • In the old version I could clear select/read : “Outside / Right” and “Inside / Left”
  • In the new dialog it is not clear for me if the cut is inside or outside.
I wonder why you add the “Breakthrought” field to make this explicite and remove the “offset direction”
thank you Peter
Sorry I misunderstood complete and was blind. I thought cutout replaces contour :man_facepalming: . Luckily I found out while the job was running that contour is still there and could stop last minute.
