Happy Holidays all!
I figured I should share two of the projects I have worked on for this holiday season.
The first one was a commission of Japan made from cherry and epoxy. It is 22 inches tall by 10.5 inches wide. Tool paths were done with a 2 flute 1/4 inch bit, a 90 deg V bit, and a 1/8 inch tapered ball nose for finishing. In total it took about 4 hours of carving, with about 1.5 hours of other finishing work.
The second is the Christmas present for my Dad. It is a carving of Desolation Sound and the surrounding islands. It is made from walnut and epoxy. It is 17 inches tall by 27 inches wide, with the tallest peak being about .75 inches above the sea level. Tool paths were done with a 2 flute 1/4 inch bit, 60 deg V bit, and a 1/8 inch tapered ball nose for finishing. It took roughly 14 hours of carving and then 2 hours of additional prep and finish work.
I can try to answer any question. Hope everyone has a happy and safe holiday season.
