Speeds and Feeds Amana 45710
Good afternoon, I purchased the Amana 45710 V-Groove bit and I am not sure what to use for feeds and speeds. I will use on both soft and hard wood. If anyone can assist that would be wonderful. Thank you so very much! Crystal
This tool:
https://www.amanatool.com/45710-carbide-tipped-v-groove-90-deg-x-5-8-dia-x-5-16-x-1-4-inch-shank.html
seems similar to:
or if you have a spindle:
so use that as a starting point?
For more on this see:
Thank you. I will take a look at the information you provided. Thank you!
Many of the Carbide3d bit numbers can be used for almost identical 3rd party tools. You can make a custom tool but just using the C3D tool numbers is easy and the F&S has already been figured out.
Thank you so much. I appreciate your response.
I would trust the below chart for an HDM/Pro. For an SO3 or any belt-driven machine, I would start by cutting these in 1/2 and then building up. I imagine the top would be 60 IPM for an SO3 or comparable machine.
Carbide-Tipped-V-Groove-Speed-Chart-v3.pdf (80.2 KB)
