Very good, not mindless at all!
That could get tricky as you would need to add to the retract height to clear your project.
Me, and I am quite new at this, I would set a 0.125 “0” flute straight bit and do the outer offsets, then set a toolpath for the 0.125 to do the clean-up, zero at top and start cutting at whatever your max depth is plus 0.003 (if you have a bit with enough tooth length)
Limited on bits right now, I’m new as well.
Amazon has an expensive but useful set,
