Spindle/Gantry Play?
After facing a 12x12" piece of MDF with my S5P and 65mm VFD spindle using a McFly cutter, I noticed a repeating ridge at the step-over lines. When the facing operation was done, I could feel a distinct series of “ramps” from one step-over line to the next, strongly suggesting that the spindle was nodded towards the front of my machine by maybe 0.1-0.15mm. When I pushed a little on the HDZ to see if there was any play, I was a little shocked. The entire gantry has fairly significant play along the in the y-axis direction (where “significant”, to me, is at least 2-3mm). The “play” I’m talking about is resulting in making the spindle nod by that amount to the rear.
Is this normal for an S5P?
-M.
Have you made sure your gantry to side rail connection points are secure and tight?
I’ve got to do some disassembly of my enclosure to be able to check that which I’ll be doing this upcoming weekend.
-M.
If you can feel movement/slop, that pretty clearly indicates a mechanical connection is loose. No, this is not normal. In addition to checking where the gantry bolts down to the Y-axis on either side, another place to look is the attachment of the Z-axis to the X-axis plate.
Absolutely a good call, Ryan. It took me a while to remember those hold-down bolts were under the plastic end plates on the gantry. When I popped the end plates off, I found three of the four bolts were loose. Tightening them up removed all of the play in the HDZ.
I’m about 99% sure those were tight when I assembled my table. Can normal ops cause those to vibrate loose? Should I consider a drop of thread lock on those four bolts?
-M.
@MarkH
I would put a small amount of blue lock tie or set up a preventive plan to check them.
