Hi
Apologies if it’s already been covered but can anyone help with how to split the g code for an advance v carve file?
I haven’t got a bit setter so would like to be able to run as 2 separate files, using my z probe between carves.
I’ve found the line in the code where the tool change happens but what, if anything, do I need to add/subtract to the separate files once split?
Thanks
Russ
