Wouldnât say itâs a bad idea, as long as the power supply is rated high enough (preferably 10-20% above) to cover the combined amperage. Only worry would be the spike power draw and noise the router could produce on the line.
When I swapped boards, I just used the original S3 power supply (cut, spliced, and stripped) but that would be a point of no return . At first anyway, did eventually swap the PS to a Mean Well
Griff
(Well crap, my hypometric precursor device is blownâŚ)
24
I too have had some noise on my A axis motor. The funny thing is, that with no power to the control box, I can hand turn it. and the red light shows up on the A stepper drive controller board. If I turn it slow, it barely makes chatter noise, but if it is turned faster, it has a louder chatter. However, if I un plug the stepper motor, and then turn it, it spins easily and without noise.
Turning the motor by hand causes it to act as a generator, resulting in the lights, and the chatter as impulses are generated by the current being sent to the stepper driver.
that makes sense. I did that because when I was running the axis, it had chatter, but now im thinking it may have been because my velocity was turned up too much in motor tuning. I turned down the velocity and am fixing to go try it. hope this works.
