Stripped x axis rail threaded holes
Had bought the extension kit and when installing the X access real to the carriage I had inserted bolts at a slight angle wondering if I can rethread them and what size I should use
Since the holes are partially open, I’d recommend sticking with M6 and just using a tap to make deeper threads, then use a longer bolt.
