There is a working pane on the right of CC and the desiging objects pane on the left pane.
I know that you can increase and decrease the working area by dragging the verticle bar between the 2 panes horizontally to make each pane larger and smaller. But it only goes so far to the left to make your design area larger and the object area smaller. And there is a lot of “wasted” space on the design objects area on the bottom. If the vertical bar could be pulled more to the left until the design objects start to align vertically, then the design area would be larger. I know this is a very minor thing, but I think it would make it nicer.
Just a thought.
