Surface Mapping In Carbide Motion
I know this has been requested before but I am bring it up again to show that there is still interest.
I recently started designing PCBs and would love to be able to quickly prototype them on my S5 Pro. Unfortunately raw PCB material is almost always warped by as much as a 1mm and even when clamped down it is rarely co-planer between the two sides. I end up having to cut deeper than I want in order to get through the copper which means that my V bit is cutting my traces narrower than desired in spots. When you have tiny solder pads the difference between 0.2mm and 0.3mm of clearance is kind of a big deal.
I am sure many of you know this, but there are several G-code senders out there that support surface mapping in order to compensate for this. Basically the sender probes a few dozen points on the PCB. It then uses those points to create a movement offset matrix that adjusts the Z Height coming from the Gcode stream to match the surface. This is useful not only for PCBs but for other engraving projects. “This Old Tony” used this technique to engrave a shark on the curved surface of a hammer:
There are even guides out there showing how to do this on the Nomade 3 with coppercli and the BitZero:
https://thomer.com/pcb-nomad3/
I am somewhat shocked that at this point Carbide Motion does not support this feature. Especially with the release of the new Nomad 4 I could see this as being a huge selling point. I would very much prefer using a Gcode sender that I am familiar with rather than some new one that was forked from abandonware with the use of Claude Code (which is what coppercli is).
Carbide3D could even make a new version of BitZero with a jack on the side that a cable with an alligator clip or a magnet on the end for connecting to smaller metal parts. That way they can probe be directly from the tool to the stock. I’d buy that.
