Hi group,
I bought a SVG file from Etsy, It’s a bottle of wine with Text inside it. In Light burn, it import fine.
But in CC, it does nothing, no importation. Any idea?
Hi group,
I would test it in Inkscape. The Layer dialog box will show the entities in the file.
A SVG can contain an image file as well as vector entities.
You would need to post the SVG file in order for someone to help.
I know bought the file, so a bit of honesty would be needed.
Usually when this happens it is because the image uses clones/elements by reference.
Opening in Inkscape and converting all Clones to Paths (I believe the command is Path | Object to Path), but note one has to ungroup, possibly repeatedly until all instances have been so processed.
Send the file in to support@carbide3d.com if you have difficulty with this and we will walk through it with you.
Will, U R the best. It is exactly that.
