Why does my svg file image (via Illustrator) shrink when I open it in CC?
Is there a setting that will open the svg file so it’s always 1:1 or 100%?
After running the touch probe, the bit height stays very low. Is there a way to change the setting so the bit is higher (at least 3" vs 1")?
Thank you.
WillAdams
(William Adams (Carbide 3D))
September 23, 2020, 4:35pm
2
Illustrator doesn’t use the industry standard DPI setting when saving an SVG — it will use a value which is correct for Carbide Create when exporting an SVG.
Carbide Motion doesn’t have a facility for customizing behavior after probing — we’ll put this in as a feature request — could you elaborate on why and if there were some other behavior which would work?
fenrus
(Arjan van de Ven)
September 23, 2020, 4:50pm
3
Illustrator can “save” and “export”
export iirc has the right industry dpm while save does not
So I have to live with the shrinkage factor?
I just want enough clearance to pop the bottom part of my sweepy back on after probing.
WillAdams
September 23, 2020, 5:20pm
5
No, just use Export SVG instead of save (may be hidden under Save for Web)
rwyoung
(Rob Young)
September 23, 2020, 6:17pm
6
Search around for a “DPI” setting that could be applied during the export. Should be either 96 or 72, 96 probably being the correct value.
gdon_2003
(Guy Donham)
September 24, 2020, 12:40am
8
Will has offered this advise before. Draw a box the dimensions you want the svg to be. Import svg and shrink/enlarge image to fit in box.
system
(system)
Closed
October 24, 2020, 12:41am
9
