In carbide create 7, I added tabs in design, set the length and depth in toolpath, but they don’t show up in the simulation…
What is the height and depth set for the tabs?
Could you post the file?
I found the problem. I had the stock thickness set at .85 and the max depth in the toolpass at
.82. With the tab set at .06 it didnt show a tab because it was not cutting all the way through the stock
Thanks
