Tee option in rectangles
When drawing rectangles, has anyone hacked how to change the orientation of the tee option? It only seems to produce that notch in the the “H” orientation. Sometimes I want the rectangle in an “I-beam” orientation. If I draw it and then use the rotate tool to roll it 90° the object loses the ability to be adjusted as a “rectangle”.
At this time, that is the work-around for that.
